Off Road Diesel
   / Off Road Diesel #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
What does it cost per gallon in your area ?
I filled up a couple weeks ago and was charged $1.40 per gallon.
   / Off Road Diesel #3
Thank your lucky stars.
   / Off Road Diesel #4
Yes, I guess so. Off road averages around $2.30 here in the Cheney/Spokane area.
   / Off Road Diesel #6
Off road vs on road diesel? I am sure this has been dealt with but I can't find it. I am getting a new tractor and wonder if there is any quality difference. Local places here sell both, with off road much cheaper.
   / Off Road Diesel #7
In idaho... no difference. Comes out of same tank. There is a dye added at pump.
   / Off Road Diesel #8
no difference..
cheaper
cant use it onroad
   / Off Road Diesel #9
I only use about 200 gal per year of off-road.
There's a local supplier that delivers for a 100G order min.
I've had far too many spinal surgeries to be lifting 5 gal cans of coal & waiting for the gurgles to stop.
Absolutely no difference in quality of fuel.
It's just got the red dye added.
   / Off Road Diesel #10
Depending on your retailer, off road diesel and the on-road fuel may be different due to fuel turnover. If you use your diesel tractor in winter, you want winter grade fuel to aid in starting. You retailer may not have the sales volume to keep up with the seasons. I do not use off road diesel for this reason. I buy diesel fuel from retailers that turn diesel fuel over frequently. Truck stops are a good source of fresh fuel that is correct grade for the seasons. BTW, I also add a bit of additive to increase the fuel's lubricity. The current low sulphur diesel fuels are not that friendly with some fuel injection systems.
1275 (A50490)
1275 (A50490)
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
