Off balance
   / Off balance #1
12Bravo
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Driving down the road the other day heading to a friends house to help grade his driveway. I noticed the tractor on the right side was humping, like a car does when there is a flat spot in the tire.
My lug nuts are tight and didn't see anything odd.
Could the liquid in my tire cause this when I'm in high range 3rd gear on the road. I don't notice this any other time except when on the road.
Just seemed odd.
   / Off balance #2
Tractor tires, especially bias plys, always do that. They sit, they get flat spots, they slowly get round and pliable again when you roll them. In cold weather in the winter it is really bad. You only notice it at higher speeds in the summer. You notice it every time you run the tractor in the winter.
The flat spots don't line up side to side with each other as you make turns and stuff, so the bumpy ride can be not too bad or more pronounced depending on the orientation of your square tires with each other.
   / Off balance #4
The tires seem to develop a flat spot. If I use my tractor frequently it doesn't seem to be a problem. I used to use the backhoe to lift the back end off the ground and put a stick under it. I had the stick cut so both back wheels touched the ground, but just barely. That seemed to help the problem.
   / Off balance #5
If you don't have enough fluid in the tires, the fluid can all end up on one side of the tire, going around in the same "spot" creating an imbalance.
   / Off balance
Glad to hear it's not just me and the machine isn't messed up. It had sat for a week or two in this heat, so this explains everything. I just didn't think a tire this large and this thick would do it so quickly.
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2022 John Deere 6175M (A50120)
2022 John Deere...
2014 Freightliner M2 106 Medium Duty Truck, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
2017 John Deere 4044M (A50120)
2017 John Deere...
Unused 2025 CFG MH12RX Mini Excavator (A50322)
Unused 2025 CFG...
28013 (A50322)
28013 (A50322)
