Mowing OEM mower blades
   / OEM mower blades #1
kmaz
Bronze Member
Charlton N.Y. (Albany)
PT 425
Just thought id pass this along. If you want to stick to the original mower blades (at least original on my late 2006 60" mower) their Oregon brand part # 90-125 available at mowpart.com for under $5 per blade. Just recieved mine.
Kris
   / OEM mower blades #2
THANKS FOR THAT INFO. SINCE I DONT HAVE A SPARE SET, I ORDERED A SET FROM THEM TODAY.
   / OEM mower blades #4
I purchased them directly from Power Trac, along with a half dozen of the spacer/bushings that go inside the bolt hole, along with a few hydraulic filters. I easily made the $50.00 minimum purchase. :rolleyes:
   / OEM mower blades #5
I have had a couple of those spacer/bushings break. Has anyone tried greasing or otherwise lubricating them. I have not done so, but it seems like a good idea.
   / OEM mower blades #6
Say, i wonder what the shipping would be out to the west coast?
   / OEM mower blades #7
Power Trac can tell you that if you call them. About once a year, I place an order for stuff and that helps to cut down on shipping costs if you can get things in one shipment.
Polaris Ranger SxS Doors with Bolts (A51573)
Polaris Ranger SxS...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
T3 Motion Patroller Segway (A51694)
T3 Motion...
