OEM greases from tractor manufacturers
   / OEM greases from tractor manufacturers #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Anyone have the skinny on the greases provided by the tractor manufacturers.
So far I have been just buying cases of the NH grease to grease most of my stuff.. though i do have some of the red stuff to for my IH cub /forums/images/graemlins/grin.gif
Soundguy
   / OEM greases from tractor manufacturers #2
I get my grease from a mid-west distributor. I use the NH "blue" EP "extreme pressure" moly for my FEL and I use Kendall Tough Tac II (red) moly for spindles and wheels etc. that are not under extreme pressure. The distributor will talk tech on grease with you for hours. I only wanted to know what he recommended, since he at lease comes off as knowing a considerable amount about grease.
He showed me the difference between some of the cheap "no name" grease and his Tough Tac II. He stuck his finger into the grease and then pressed his thumb into the glob. When pulling his finger and thumb slowly apart he noted how far apart his fingers got before the line of connecting grease parted. With the "cheap" grease, almost no grease clung between his finger and thumb. With the high moly tac stuff, it streached almost an inch before it wasn't any longer connected between his finger and thumb. His point was that the better grease would cling to the bearings or other metal and not just fall off as easily. He said that the cheap grease has a high parifin base and will harden and fall off more easily.
Oh yeah, JD, NH, Pennzoil, and Cat grease came from the same plant he said. He also supplies TSC stores and they "private label" some quality grease and also some cheap stuff. That really outa confuse people. Just when you think you can make a statement like TSC grease is poor quality, you may buy a tube that is of the highest quality! I suppose they would price it accordingly at the store? /forums/images/graemlins/confused.gif
   / OEM greases from tractor manufacturers #3
Soundguy,
What is the red grease and where do you get it ?
Ben
Fina marson red.
I grab a case of it from our fina dealer every now and then when he makes a delivery to our office.
Soundguy
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
American G-Model Pump Jack (A55218)
American G-Model...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
