plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,393
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
Yesterday I started using a rainbird impluse sprinkler on a tripod. Something weird happened I cannot explain?
The sprinkler started out with good pressure. Spraying at maximum distance and "ratcheting" back and forth. All good. No other draw or demand on the water system.
20 minutes later, the sprinkler was no longer ratcheting side to side. The flow was reduced-- it was now spraying at about 75% of the former distance. I turned it off and checked the debris screen at the coupler. There was a little debris but seemingly not enough to cause a problem. Turned it back on-- once again normal pressure and normal operation. Again, no other use or demand on the water system.
20 minutes later, it was again stuck and not moving side to side. I suspected a well problem? I inspected the well and pressure there was 60lbs, which is the maximum setting. (It is set for 60hi / 40low)
I can't see the sprinkler from the well house, so I can't evaluate if it works correctly at 60psi but not 40psi? This is the same sprinkler on the same hose bib using the same hose as last year when it worked fine?
I'm stumped ... ideas?
