Odd size fitting
   / Odd size fitting #1
TonyF
Huntsville AL
BX200D w/FEL, B21 TLB, KX91-3SS. F700 Dump Truck
Anyone hear of a 13/16 x 14 O-ring fitting? It connects a hydraulic hose to hard pipe on my mini-ex.
I'm in the last stages of installing a thumb on it, but am having a heck of a time finding some sort of adapter to go from the o-ring female end of the pipe to AN-6 hose. This fitting is what Kubota used, obviously for a different size hose. I'm about ready to cut the pipe and weld on a standard size end.
thanks,
Tony
   / Odd size fitting #2
Can you post some accurate measurements please? I suspect it may be BSPP or Metric.
   / Odd size fitting
Its .811 inches / 20.43mm in diameter across the threads with a 1.75 mm pitch, I too thought it was metric, but I could not find a reference anywhere for that specific size. It very well may be a special metric size. But it seems to be closer to 1/2 British.
Tony
   / Odd size fitting #5
Got me Tony...I am stumped.
   / Odd size fitting #6
thanks,
Tony
Tony,
what brand of mini ex do you have? The Japanese had some weird sizes and styles for awhile that where similar to to BSPP.
Roy
   / Odd size fitting #7
JIS
Japanese Industrial Standard: This coupling looks similar to our MJ and FJX fittings. There are two major differences - the threads are BSP and the seat angle is only 30-degrees instead of 37-degrees.
   / Odd size fitting
Thanks everyone. Its a KX91-3SS. 2005 model year. JJ, I looked for some JIS to JIC adapters, but didn't see any.
I ordered a handful of British O-ring to JIC flare adapters from McMaster and Discount Hyd Hose, as British seems to be the closest match. Hope to have them Friday. If they don't fit, I'm going to cut off the end of the pipe and weld on a new fitting. If that doesn't work for some reason, I'm loading it on the trailer and dragging it to the closest hyd shop in town.
Stay tuned :confused: I hate plumbing of any sort.
Tony
   / Odd size fitting #9
It looks like a 1/2" BSPP (British Standard Pipe Parallel) to me.
According to my charts, that will be a 13/16-14 thread.
The only thing that looks odd in your picture is the O-Ring. Usually, BSPP fittings have either a bonded seal (metal washer with rubber seal) or a captive O-Ring held in place with a metal washer.
Could be the captive washer is gone from your fitting, but otherwise, going from the dimensions and photo you supplied this looks exactly like 1/2" BSPP.
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
13 in Large Excavator Bucket (A52377)
13 in Large...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2005 INTERNATIONAL 4300 WRECKER (A53426)
2005 INTERNATIONAL...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
