Odd Question - My freezer is sweating??? WTH?
   / Odd Question - My freezer is sweating??? WTH? #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
So I'm busy fixing and cleaning the basement recovering from the flood 2 weeks ago and I am very aware of everything.
So yesterday I noticed the freezer door (mostly he middle and bottom) were wet like a glass of ice water in the summer. on one side there is another spot similarly wet.
It is humid, but WTH is going on? the freezer is full (of course) and has been for a while so it also needs a defrost. The motor runs like it is supposed to.
Any ideas?
Is this a problem I need to fix?
Thanks in advance,
David
   / Odd Question - My freezer is sweating??? WTH? #2
C'mon David -
Your air is probably super saturated and any cool smooth surface can cause condensation. Pump some drier air thru there before mold forms ON the freezer and in places difficult to get to.
It's happened to me before in Northern Virginia.
C'mon David -
I burned the wood stove for days after the flood, but it is humid and damp...
Thanks!
David
   / Odd Question - My freezer is sweating??? WTH? #4
Some old freezers have a door skin heater element to prevent condensation. Yours may have become disconnected or burned out. Dont know whether its still done.
   / Odd Question - My freezer is sweating??? WTH? #5
Running the wood stove is really a limited way to remove the moisture. It relies on the warm air that escapes, to draw in outside air that is drier to replace it.
In the winter, the stove dries your house out, because the air that is drawn in to replace the heated air is very dry. If the outside air is very humid, like it usually is this time of year, you don't get that effect.
Your current outdoor humidity level is 96%, so running the wood burner will not get the air your basement any drier than 96% humidity. You need to get it to 50% or below asap, to prevent mold growth.
This job requires dehumidification, from dehumidifiers, or air conditioning to remove this moisture fast.
If it gets warm enough, run your air conditioning as much as possible.
Rental equipment, (i.e. fans, and dehumidifiers), would be ideal, but is likely in short supply, if your area has had flooding.
As stated, you only have a short amount of time to accomplish this before the mold takes over. Then, the job gets harder.
   / Odd Question - My freezer is sweating??? WTH? #7
Just wipe it down to remove the excess water. The freezer I have in my garage sweats also when the humidity gets high. It isn't a problem and I have never had mold on it but we rarely have more than a few days at a time of really humid weather. THe last week or so has been near 100% all the time with intermittent showers followed by rain then cloudy for a day or two. Finally got some sun yesterday morning but rains moved in in the afternoon. Today its sunny again.
I think the sweating is due to a poorer insulation in the doors and it is only on the door and not on the sides so that is quite common to see it in the south.
   / Odd Question - My freezer is sweating??? WTH? #8
My older fridge/freezer has a manual switch in the freezer compartment, that shuts off the door heaters.
I'd start with a dehumidifier etc, as posted, but check for a manual heater switch. I leave my door heaters off in the Winter, and turn them on in the Summer when I see door sweats - I have central AC, but don't run it much.
Rgds, D.
   / Odd Question - My freezer is sweating??? WTH? #9
Flood...put a humidistat in the basement and take a reading. I'll bet you are "tropical". Do you have windows in the basement that you can put a fan in to "pull" upstairs air through the basement and out? As noted above, your basement will have some mold issues soon if I'm right.
   / Odd Question - My freezer is sweating??? WTH? #10
Humidifier ASAP!!!!!
Toro Groundsmaster 7200 72in Zero Turn Mower (A42744)
Toro Groundsmaster...
2019 BOTE Gatorshell Rover Skiff w/ Trailer (A42744)
2019 BOTE...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
2000 CAT D6R DOZER (A45046)
2000 CAT D6R DOZER...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A42744)
2012 Ford F-250...
2006 Chevrolet 3500 4x4 Utility Truck (Diesel), VIN # 1GBJK33D56F253355 (A44391)
2006 Chevrolet...
