odd occurance starting ck20
   / odd occurance starting ck20 #1
wade simpson
dartmouth nova scotia
kioti ck20s
When I went to start my tractor this weekend I followed my normal routine, turned the key, waited for the glow plugs to go out and then turned the key to start it....nothing.. the whole start system shut down like I had no battery. I checked the battery connections, fuses and eyeballed the system as much as I could see, everything was fine. I had to disconnect the battery to reset each time I let the glow plugs shut off before turning the key
Tried a few more times then got very worried as I had just recieved 8 tons of gravel. Out of desperation I just turned the key all the way without waiting for the glow plugs and he fired up perfectly, man, I was one relieved guy.
Later on, after running for around 6 hrs, I turned it off and started letting the glow plugs turn themselves off..he started normally.
Any ideas?
   / odd occurance starting ck20 #2
Our little monsters are notorious for having key switch problems. Yours may be developing this issue. A squirt of WD-40 worked for me. I need to find some of that spray Teflon, I hear it is the hot ticket for this problem.
Where do you spray the fluid? Into the key hole or the connections in the engine compartment?
Can you hotwire the tractor, it almost came to that.
   / odd occurance starting ck20 #4
Yep, right into the key hole, but just a squirt. I'am sure it can be hot wired, but I would need to study on it for awhile. I am not sure if the CK20 fuel solenoid is power on running or power on to stop. Some need power to open allowing the engine to run, while others are only energized a few seconds to close, shutting the fuel off and stopping the engine.
   / odd occurance starting ck20 #5
Yep, I agree with Sandlot
   / odd occurance starting ck20 #6
Whether it's Power-on or Power-off fuel system depends on the serial number of the tractor. If it has a fuel shut-off pull knob, it's definitely the older Power-off system.
We would need to know which system it has to determine what might be causing the starting trouble. Key switch is a good place to start.
Well, if it is a component problem I'm still under warrenty. What would be a reasonable on site quick fix if the key won't start it?
There is no pull knob unless it is interlocked with the start system and I can't see it. The tractor is a 2009. What numbers am I looking for on the serial #?
I haven't called the shop yet.
   / odd occurance starting ck20 #8
You definitely have a Power-On System. Electrical issues can be a little annoying to trace. When the key switch is turned to the start position, the power is cut to everything else so full power goes to the start circuit. When you turn the key to the "On" position to glow, you should hear a clap from under the hood. That is the fuel solenoid opening to allow the rack to move from the off position. If you don't hear the clap from the start solenoid, you have a power problem. It's possible to glow, but not have enough power to run the start circuit. If you hear the clap, have a good glow, and then nothing, it could be a component issue, ranging from the Battery, Display Unit, Key Switch, Relay, or Harness.
As far as components, you really need to have the system tested, or test it yourself, starting with a load test on the battery.
Since it is still under warranty, the best thing to do is contact your dealer. They will know the sequence to test the system.
I definitely hear a loud click when I turn to the glow position then a softer click when the plugs go out. Once I turned the key to start, the whole system shut down. I figure it must be some part after the glow plug cycle that is killing it. I'm a little mystified as to why it works if I don't wait for the glow plugs to go out. I hate electrical problems.
It did work normally later on in the day. Is it possible that some moisture was shorting the system and then dried later? The tractor is outside all the time, covered.
I'll be calling the shop today.
Thanx for all advice
   / odd occurance starting ck20 #10
My 2005 dk45s did the same thing after owning it for about 6 months. I had a bad cell in the battery. Could put it on the charger for 5 minutes and then it would start normally for a week. If I put the battery on a charger it would pass a battery test. Found the problem when it wouldn't start one day and then just pulled the battery and had it tested and it tested bad that day. Did it again in May of this year and had to replace the battery again.
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
2016 Ford Explorer...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2020 KUBOTA RTV...
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
