Odd little Ford-Geo-Metro tractor....
   / Odd little Ford-Geo-Metro tractor.... #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
If you can believe the ad, I'm sitting here wondering how you stuff a 50hp chevy engine into such a small tractor?? And then get all the linkage and shafts to mate up?? Must be some kind of a mechanic/machinist/magician to make that sort of engine swap!!
Here's the ad:
Ford Tractor - $1150 (alpharetta)
1989 Ford 195 Tractor with a geo metro 1.0 chevy motor. 50hp. Runs great and motor is very clean. Has 3 point hitch NO PTO. Has hookup in front for a bucket or logspiltter.
(I deleted the contact info, but it can be found if you search the Atl, GA craigslist. )
   / Odd little Ford-Geo-Metro tractor.... #2
geo metros did NOT have chevy motors.
They were 3 cylinder suzuki motors. 54hp, aluminum block, 1000cc. Great little motor. Could be lifted by one man (80lbs), transmission actually weighs more and sits in front of the engine (transverse mounted)
Probably not all that hard to made it up as the combo is light.
   / Odd little Ford-Geo-Metro tractor.... #3
In case anyone is curious (as I was), the 195 apparently had a 20 hp Kohler when stock.
   / Odd little Ford-Geo-Metro tractor.... #4
For a time, there was some garden tractor pulls around here...and I think some of em were for an unlimited class with all sorts of engines. Could this come from that category of tractor?
Along these same lines.....I recently saw an 8N ford on the local Craigs List. It had a flathead V8 engine in it....and from the picture....it looked like it came from the factory that way. This thing was parade ready...and looked pretty cool. Was this once a popular conversion?....or, one of a kind? I never saw one converted such as this before. :confused:
   / Odd little Ford-Geo-Metro tractor.... #5
Probably a Funk conversion. Definitely not a "one-off".
   / Odd little Ford-Geo-Metro tractor.... #6
The add has been running for months.It's probably an absolute mess and not very practical.Looking at the pics. it seems the engine cover is cut up and just laying in pieces on it.My guess if you started it up parts would start flying.Also thinking about the safety issues might get some one hurt.
   / Odd little Ford-Geo-Metro tractor.... #7
In Several magazines I've seen many flat 8's stuffed into a 8N and looking stock; Wouldn't be all that hard to do- parts were more interchangeable back then. Kinda think this is a more recent popularity conversion, as the 8n's became more popular in the restoration world.
   / Odd little Ford-Geo-Metro tractor.... #8
Here's a guy that put a Geo engine in his JD 140. I came across it a few years ago when I was looking for info on my own (at the time) JD 140. He goes into a little detail about how he did it. Jim makes it sound like it's not all that uncommon to do a mod like this.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2014 KENWORTH T800 KILL TRUCK & TRAILER (INOPERABLE) (A53843)
2014 KENWORTH T800...
2012 FRAC TANK (A53843)
2012 FRAC TANK...
