Obvious Dumb ??s - Foam Filled Tires....
   / Obvious Dumb ??s - Foam Filled Tires.... #1
hobbyfarm
Veteran Member
Hidalgo County, TEXAS
After you've foamed your tires to make them bulletproof, <font color="red">What happens when it becomes time to replace the tires?</font>
Eventually the tread will wear to the point that traction will become a rare and precious commodity.
So, are the tires cut off the rims?
Also, does the foam ever break down over time?
Like some other foams, does it turn to powder over time?
   / Obvious Dumb ??s - Foam Filled Tires.... #2
I don't have all the answers you're looking for. The foam does not break down. I don't think you can get Ag tires recapped but I have heard of a shop being able to recap foam filled tires. Before you quote me on that, talk to the companies that are in the recapping business in your area especially those that also sell heavy equipment tires.
   / Obvious Dumb ??s - Foam Filled Tires.... #3
We used to get the R-4's recapped for Bob Cats. they would prep, and cold cap, right on the rim. Gary.
   / Obvious Dumb ??s - Foam Filled Tires.... #4
I was driving and seen Ford 5600 one day on roadway and his front tire shreded away due to so many cuts and never losing airdue to foam fill, He lost control and flipped... It was a ugly day. But he is Ok now
   / Obvious Dumb ??s - Foam Filled Tires.... #5
"The foam does not break down."
Yes it does.. all 4 of my finish mower wheels look half flat now. And.. the front filled tires on my tractor have squish/flat spots. But I'd do it again.
I have asked at the dealership if they can try to re-fill/ fix the squishy/flat spots.. since they send the tires out.. never got a reply back.
2015 DODGE RAM...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2008 Ford F-250 (A52748)
2008 Ford F-250...
Gradall 534C (A47384)
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
1600 gal Poly Tank (A50515)
1600 gal Poly Tank...
