OBD2 Scanners/Analyzers
   / OBD2 Scanners/Analyzers #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
Anyone have a PC based (USB preferably) OBD2 scanner they like? I have a simple code reader, but I am looking for something more advanced to help keep my aging fleet on the road. I would like one that reads the senor values in particular...
I am fighting a P0106 MAP sensor problem in my Buick right now. Sensor has been replaced, and I have the factory service manual-but I need to read the sensor values.
   / OBD2 Scanners/Analyzers #3
I've got a USB one from www.autoenginuity.com. Very plug and play with real-time data. So far, haven't found anything it won't work with (gas and diesel). I bought the expansion modules for Ford, Chevy and Honda cause I needed the advanced features for ABS and transmission codes.
IXLR8 said:
I just ordered one of these, it is suppose to be able to pull code, reset them and display some of them real time. I have not received this yet... I can't say for sure exactly how it works.
ScanGaugeII - Scan Tool + Digital Gauges + Trip Computers
Thanks Jim, I looked at that-but I am just not sure goes into sensor values and such? Not sure on this one yet-but would love to here your experience when you get it.
tlbuser said:
I've got a USB one from AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics. Very plug and play with real-time data. So far, haven't found anything it won't work with (gas and diesel). I bought the expansion modules for Ford, Chevy and Honda cause I needed the advanced features for ABS and transmission codes.
Cool, so the basic unit is $250.00 correct? I was hoping to stay under $200 but it's hard to choose-there are lots of them out there with big claims!
   / OBD2 Scanners/Analyzers #6
Whatever you do, don't lose the interface unit. Most of the ones I checked, they'll darn near give away the software but the USB interface costs almost the same as a whole package. Software coding..ain't it great :p
If you check Ebay, you might find it's $50.00 bucks cheaper AND the same vendor :confused: I had a couple others, one in particular which came from a co. in WV, which are total junk. They claimed what they couldn't do and getting my money back was tough. I had to contact the WV AG's office for one of them :mad: Hint, they had Pro in their name...
If you got bucks to spend....Snap-on has had some nice ones. chip programming capabilities, real time, etc...
   / OBD2 Scanners/Analyzers #7
Check out this obdII USb Scanner.
I have it since 2 years now and it is great. You can read sensors in real time and it is C.A.N compatible for newer cars ( 2006 and UP).
My two cents,
Bizioto
   / OBD2 Scanners/Analyzers #8
I have one of these and I am very happy with it.
It gives you the codes as well as live data for trouble shooting.
   / OBD2 Scanners/Analyzers #9
If you have a laptop with USB ports or a desktop you can get close to the vehicle, Check out AutoTap - OBDII Diagnostic Scanner I have it on my laptop and it has served me well. I got it when I was in the market for a new (used) vehicle and wanted to avoid problems. I have only used it twice on that vehicle for problems that were actually caused by blown fuse or loose connections. Without the scanner I would have been chasing my tail the way the symptoms presented them selves.
The web site has a lot of useful information and troubleshooting tips.
Vernon
2019 PETERBILT 567 TRIAXLE (INOPERABLE) (A52472)
2019 PETERBILT 567...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
