O.T. air compressor maintenance
   / O.T. air compressor maintenance #1
ratropia
Hi all. I have a question about a shop air compressor. I have a 30gallon 150 psi compressor. How often should I drain it out form the bottom to remove moisture? The manual states after every use. I think that is a pain in the rear. Will it hurt to leave it full of air and just drain it once a month or so? How about in the winter or summer, will that make a difference?
Thanks Rick T.
   / O.T. air compressor maintenance #2
What if you just crack the bottom drain valve a bit? The water will sputter out and the compressor should be able to keep up with the leak. I forgot to drain mine after a while and it was 1/3 full of water !!!
   / O.T. air compressor maintenance #3
Depends on where you live and how much you use it. Down south we need to drain more. Once a month is probably fine unless you use it a lot. I use to work for Senco and we had companies that DID need to drain daily.
Leave it full is fine, unplug, turn off switch or put in a tank cut off valve incase a hose breaks and it starts running while you are not home.
Good Luck,
Rob
   / O.T. air compressor maintenance #4
There are self activated liquid drain vales on the market.:D :D
   / O.T. air compressor maintenance #5
I bought a couple of brass nipples, a 90º elbow and a small gate valve to replace the valve on the bottom of my tank. Now all I have to do is bend over and crack the gate valve for a couple of seconds, lots easier than the factory drain.
A friend has one of the self activating drains on his compressor Egon refers to and that is a really sweet setup.
The gate valve sounds like a good idea. So it's okay to just let the water out while the tank still has pressure?
Thanks Rick T.
   / O.T. air compressor maintenance #7
If you go to just about any truck stop or place that sells parts for big trucks you can get a truck air tank drain valve. They usually have a 6 foot cord on them so truckers don't have to crawl under the truck anymore to drain the tanks.
I have two big compressors i my shop and put these valves on both of them. The pull cord comes out from underneath and I zip tied the handle end up near the pressure switch.
Now whenever I walk by them I just give the cord a pull and dump the water out real fast.
I did this about 5 years ago after getting down on my hands and knees and getting nailed by a black widow that was living under there. I don't reach under anything I can't see anymore.
   / O.T. air compressor maintenance #8
Thanks Rick T.
Much more excitement when the tank has air!! :D
   / O.T. air compressor maintenance #9
Thanks Rick T.
I currently have the same arrangement as LarryD, and I never drain the air from my tank. But yes, I drain the water after every use. Leaving the water in there will just cause the tank to rust sooner.
Genie GTH-644 (A50490)
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
