O-ring is hard to get????
   / O-ring is hard to get???? #1
missesalot
Bronze Member
Brockport NY
tc45d
I had a leak on one of the quick connects for the FEL on my tc45d. the o-ring was beat up. I called the dealer, they cannot figure out which o ring it is. I went to two autoparts stores and a kubota dealer, everyone has lots of o-rings but none that match this. Its has a very small thickness, if thats makes sense, measures ~.067 with a caliper. Am I missing something? Am i trying to match it too specifically?
   / O-ring is hard to get???? #2
That doesn't say much for your dealer.
Try your local JD dealer and ask for their "Face-Seal O-Ring" assortment box. It may be in the workshop (You don't want to buy a whole box-full).
Some of these FSOR's are thin in section and they have a series of sizings.
The assortment box is yellow plastic and has a sizing chart inside the lid which may be useful.
I agree about the dealer. After reading your post I believe I was able to find it, I will make an attempt to confirm the part number with the dealer and order a few extra. On the part listing it lists an item called a backup ring as well. Both rings were included in the line item for the female quick coupler. What is a backup ring for and where does it go?
   / O-ring is hard to get???? #5
Quick connects are cheap. I think most just replace the whole thing and not try to worry about the seals
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
2014 Doosan DA30 (A52748)
2014 Doosan DA30...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2803 (A50460)
2803 (A50460)
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
