O-Ring Boss Torque Specs?
   / O-Ring Boss Torque Specs? #1
ttkeeler
Bronze Member
Anyone got the torque specs for a SAE #8 Male O-Ring Boss fitting?
   / O-Ring Boss Torque Specs? #2
I have no specs, but they do not need to be super tight since the O-ring does the sealing.
   / O-Ring Boss Torque Specs? #5
You're quite welcome. It is good that you want the proper torque, but I wouldn't get too hung up on it. I don't know of any mechanic that follows the proper torque procedures for hydraulic fittings. But then, years of experience does help too.
Not much experience here with hydraulic fittings but a lot of years with other parts and pieces. I just didn't want to overtorque something with foot pounds when it should have been inch pounds.
   / O-Ring Boss Torque Specs? #7
the boss fitting is probablew the only one I use a torque wrench on I had one blow out once tacking the trhreads with it , on a brand new log splitter the very first time I test ran it. be carefull:)
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2023 JOHN DEERE 8R370 LOT NUMBER 200 (A53084)
2023 JOHN DEERE...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
