Nylon Hose Protection - Can be cut?
   / Nylon Hose Protection - Can be cut? #1
CHDinCT
Veteran Member
Conn. & Florida
Kubota BX25, Z422-KW
Quick question for anyone in the know on nylon hydraulic hose protection - can I buy a bulk quantity, say 25', and cut it down to fit multiple hose assemblies - like for my HTL and log splitter hoses? I'm just not sure if you cut this material will it unravel like regular clothing material or stay as cut? Thanks
   / Nylon Hose Protection - Can be cut? #2
try a little heat at the ends of the nylon stuff.
personally I us spiral cut plastic loom its tough easily threaded onto hard to get to spots and you dont have to un hook your hoses.
   / Nylon Hose Protection - Can be cut? #3
Cut it to length then burn the ends...works great.
Thanks guys. Should have thought that heating it would melt it in place. Plastic loom is an interesting idea too.
   / Nylon Hose Protection - Can be cut? #5
I put the split plastic wire looming on my hoses over 7 years ago when new and it has worked great. I just use some nylon cable ties at each end to hold it on, they go bad after a few years and you have to replace them but the looming has stayed in excellent shape. My tractor has stayed outdoors all of it's life too. When a hose springs a leak it helps keep it from spraying everywhere too. I bought bulk rolls of it from NAPA
   / Nylon Hose Protection - Can be cut? #6
I tucked the cut end, into the sleeve and wove a nylon zip tie through the two layers, and snugged it up! Worked great! Same as SM. Gotta believe most hydro-shops are cutting off a 'bulk' spool. ~Scotty
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
2011 Toyota Corolla Sedan (A53117)
2011 Toyota...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
2016 Chrysler Town & Country Van (A51694)
2016 Chrysler Town...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
