justman777
Platinum Member
All,
I've got what may be an issue with my three point and would appreciate some input to see if this is abnormal behaviour.
My three point will intermittently "jump" back to the set height. I usually notice it while the tractor is at idle, but I believe it's happening while I'm working too. Just can't tell while I'm working because I'm driving over ruts, gopher hills, etc. Happens about every 10-15 minutes. I can usually tell when it's going to jump because the engine bogs down just a smidge, the trans makes an odd gurgling noise, and then the three point will jump back to the set height. This was happening about every 3 minutes, but I changed out the MLS valve under warranty and it went to a the current 10-15 minute time frame between jumps. It only tends to happen when I have my ballast barrel (1200 lbs) or my shredder connected....both heavier implements. Makes me think the heavier weight is causing fluid to bypass somewhere.
Anyone else experience this? Normal behavior?
BTW, my three point and loader will also leak down slowly overnight.
Appreciate any input!
Thanks!
Thanks!
