NX4510 HST Power
   / NX4510 HST Power #1
tmanmi
Kioti NX4510 HST
Has anyone pulled a moldboard plow with a NX HST series. I have a NX4510 HST and I have not been impressed with the HST power. I expect a little power loss in High range but it seems to have trouble pulling its self down the road in high with out pulling anything. A slight hill will cause rpm loss and you have to let up on the peddle with WOT. Medium is a little better but more rpm loss that I would expect. I am asking about the plow because I dragged some logs in low range and experience more rpm loss than I expected. I admit it was a good size load but would expect more wheel spin in low than rpm loss. I came from a gear drive kubota and debated with going with an HST. Not impressed so far. Otherwise I really like the tractor and the features.
   / NX4510 HST Power #2
Dose not sound right to me. High gear will for sure bog down but not low range. i have pulled trees out with my 2538 mahindra and in low it will spin tires well before bogging down . might change hydro fluid and filters and see if that helps.
   / NX4510 HST Power #3
HST provides max power to wheels as load is taken up. Therefore, an excellent transition for moldboard plowing.
I expect a little power loss in High range but it seems to have trouble pulling its self down the road in high with out pulling anything. A slight hill will cause rpm loss and you have to let up on the peddle with WOT (?) . Medium is a little better but more rpm loss that I would expect.
HST is not a go-fast transmission. It is a low-speed, high torque transmission in every range.
VIDEO: how hst transmission works - YouTube
Have you checked the level of your hydraulic fluid?
   / NX4510 HST Power #4
If your tractor hasn't had a chance to run hot, the DPF may be a little clogged. I ran my tractor that way for the first two months wondering why it was gutless.
   / NX4510 HST Power #5
In low gear, my HST tractor can still pull most anything. Check your HST fluid level or change fluid and filters. Also check to see if you did not leave your brake on. In low gear, you can still move with a brake on, but experience limited pulling capabilities. I found this out the hard way, after several hours of trying to figure why my tractor lost its pulling power.
Hate to say it, but a tier4 tractor will automatically go into "limp mode", at about 50% power level, if your regens are not clearing out the DPF filter properly. Perhaps doing a high RPM manual regen to see if it helps with power improvement and hope it solves your problem.
   / NX4510 HST Power #6
Been there done that gone to Gear I can稚 believe the difference! Don稚 get me wrong there are pros and cons to both. For my farm work it痴 Gear for me
   / NX4510 HST Power #7
I agree that high range is too tall. Wish it was geared down slightly. M range will bog when pulling a box blade up hill or even when blading. In L my NX4510 will spin tires and rarely bog unless pushing into a pile with bucket. You do need to learn to back off pedal when machine starts to lose rpm. That's why I sometimes wish I went with the NX 5010. Maybe a little less bog. Remember that this is a pretty big and heavy tractor for 45 hp!
   / NX4510 HST Power #8
If its helpful, here's information from my experience too.
DK45se HST. High is useless for all but road going, long distances, with light load. Medium is for getting around property, going to the location of work to be done, and a lot of medium duty, fasted paced, loader work. Medium will still bog down the HST if I'm trying to go up a very steep incline at full medium speed. But Low is a powerhouse. Snow blowing, rotary cutting, traversing very steep inclines with loads, pushing heavy things, burying you tractor to the case and having to call the neighbor so he can pull you out with his Komatsu PC200LC. It's best to be in low speed for high demand load anyway, your pedal is depressed further, meaning more oil volume through the cooler, as the swash plate of the HST axial piston pump if angled more. Low gear is a powerhouse, comparable to any 45hp geared tractor I have used in a lower gear.
Whether or not its advertised this way, an HST tractor is best used as a utility tractor, excellent for fast paced, forward reverse loader work, and general "some of this and some of that" utility. a comparable HST vs geared tractor, one cannot beat the ease of an HST for quick loader work. However, if you are doing 100s of acres of straight rotary cutting, lots of medium to slow paces row work, where you are going one speed, high load, for long distances for long periods of time, an ag tractor is best as a geared tractor, for now.
It's hard to say if what you are experiencing is normal without being in person.
   / NX4510 HST Power #9
DK45se HST. High is useless for all but road going, long distances, with light load. Medium is for getting around property, going to the location of work to be done, and a lot of medium duty, fasted paced, loader work. Medium will still bog down the HST if I'm trying to go up a very steep incline at full medium speed. But Low is a powerhouse. Snow blowing, rotary cutting, traversing very steep inclines with loads, pushing heavy things, burying you tractor to the case and having to call the neighbor so he can pull you out with his Komatsu PC200LC. It's best to be in low speed for high demand load anyway, your pedal is depressed further, meaning more oil volume through the cooler, as the swash plate of the HST axial piston pump if angled more. Comparable to any 45hp geared tractor I have used in a lower gear.
   / NX4510 HST Power #10
I also have a 4510, and in Low it always seems to spin in 4WD before running out of power. I run mine so that the RPM is around 2k, higher if I know I'm going to be working it hard. This is before the linked pedal activates. That way, the engine is not trying to "catch up" when you push the pedal down, it is already there. I also had my pedal recalibrated which made a big difference. It wasn't linear at all - the last 10% was double the input. Once recalibrated, it was nice and linear which made operation smoother.
TEST BID LOT (A50774)
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
PALLET OF SPREADER MOTORS (A51244)
PALLET OF SPREADER...
1986 Diesel C70 Grain Truck (A50514)
1986 Diesel C70...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
