NX series cruise control????
   / NX series cruise control???? #1
kapper
Vienna, IL
Branson 7845C
OK, I'll admit I didn't real the entire manual on this one, but it should be a no brainer... My cruise works when I set it just fine (forward/transmission cruise, not PTO cruise). My problem is the + and - don't do anything. Isn't it supposed to increase speed every time you push the + while the cruise is engaged? Or am I missing something? I've messed with it quite a lot and simply can't figure it out.... Unless it is not functioning properly.... Any help is appreciated. Thanks.
   / NX series cruise control???? #2
I am with you on this one. All i know is its not like our Automotive cruse control and unless I am in a open field doing bush hog work its useless.Maybe one day i will get all the gadgets on my machine figured out. But it is a wonderful machine so far
   / NX series cruise control???? #3
First while diving turn on your drive cruise. Second turn on the PTO cruise and then you are able to increase and decrease RPMs by 50rpm increments. Maybe you are not turning cruise PTO on.
2014 PETERBILT 388 (INOPERABLE) (A52472)
2014 PETERBILT 388...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
2014 Ford Explorer XLT SUV (A50324)
2014 Ford Explorer...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 John Deere 6155M (A50120)
2016 John Deere...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
