Loader nx 5010 HST excessive side to side joystick play (3-4 inches!)
   / nx 5010 HST excessive side to side joystick play (3-4 inches!) #1
Bigfish50
Bronze Member
Gainesboro, TN
Kioti NX5010 and 54 Massey Ferguson TO35
Hi All,
This is a repost. I initially put this question at the end of this thread:
https://www.tractorbynet.com/forums/kioti-owning-operating/396463-nx4510hst-fel6010-joystick-cable.html
Since my issue was not exactly the same as the OP in the link above I felt it best to start a new thread. I've just encountered a similar issue with my 2017 nx 5010HST open station tractor (~240hrs) and would like to ask a question. While my joystick controller is still allowing full control of my loader bucket after using it today I did notice there is a lot of excess play in the side to side action of the controller which curls up or dumps the bucket. Didn't notice this level of play in the controller until today and I thought there might be a bolt or screw loose somewhere in the assembly. I took the joystick assembly off the tractor and did not see anything that was loose per se. I did find the hex head bolt that holds on the "dummy" ball & pin but it did not appear to be loose from what I could tell. (didn't have any allen wrenches in the field). That dummy pin does move very freely so hoping something didn't fall off. Anyhow, based on this thread it appears I may be able to adjust the cable to pull the extra play out of the joystick so my question is this.. Adjustment is made at the joystick controller or at the joystick control box under the tractor? I have a FSM but it was not clear on how the adjustment is to be made. Any help much appreciated. My 2-year bumper to bumper warranty expires at the this month so wanted to establish best course of action quickly. Dealer is 70 miles away so like to resolve it without a trip if you know what I mean.
Thanks!
Bob
All, problem solved. Turns out the hex head bolt that holds the "dummy pin/ball piece in was very loose. After using a #5 metric Allen wrench I was able to tighten it up and now all the slop is gone. If it loosens again I may consider using some thread sealer on the hex head bolt.
Thanks!
Bob
   / nx 5010 HST excessive side to side joystick play (3-4 inches!) #3
Bigfish50, thanks for sharing your experience. I haven't run into this, but it's good to know about.
I'm having some trouble visualizing what you're describing. When you say "joystick assembly" are you referring to the joystick FEL valve, at the lower end of the curl/dump cable (pic on left below)? Or the assembly at the upper end of the cable (pic on right)? Can you describe from the pics where the "dummy pin/ball piece" is that you tightened?
Sure Threepoint. You already have a picture of the joystick assembly (picture on the right) in your attached picture. Here's another view of the joystick which is on top next to the operator's station where you can see the hex head bolt out and it is attached to the dummy pin/ball. That hex bolt is what came loose. Too much more and I suspect it would have fallen out.
Thanks!
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
KUBOTA 1140CPX RTV (A51406)
KUBOTA 1140CPX RTV...
UNUSED Metal Three-Layer Rolling Tool Storage Cart (A50860)
UNUSED Metal...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
