NW T7060
   / NW T7060 #1
marksmu
Bronze Member
Houston TX
66Kubota M900 92 Hp, Ford 6610, Ford 1700
Anyone bought one of these, and have a semi-recent price?
Im closing on one next week, and want to be sure Im in the ball park.
3 remotes, deluxe cab, 10 weights, ground radar, duals, loader plubmed...basically everything but the super-steer.
   / NW T7060 #3
There is not enough information in your post to give any real help with.
By you saying it basically has everything but the SuperSteer.............does that mean it does have the Sidewinder II? Infoview III touchscreen display? Guidance ready?, CVT transmission? Heated winshields? Duals?, Leather drivers and instructors seats?, Hi flow hydraulic pump? 3, 4, or 5 remotes?, cab suspension?, Radar, 112 or 119 bar axle, ect?
These tractors can vary by $25,000 very easily.
Brian
   / NW T7060 #4
Brian
You missed terra glide ;)
   / NW T7060
Go price one from another dealer. Why take the word of a total stranger here?
I have had it priced by three separate dealers - two right in the same place - one slightly better. Problem here is that there are none of these in the Houston area of Texas right now. Both dealers are having them shipped down. They are however quoting different tractors, as the serial numbers are different.
When I said all the options, I was pretty much referring to the standard ones that are on the deluxe cabs - without the super awesome upgrades I cant afford.
its priced with the following:
deluxe cab - with ac/heat
deluxe air ride seat
loader ready, joystick and valves
540/1000 pto
Cd/Radio + deluxe upgraded speakers
3 distr eletter midc jstick control
power command automatic transmission
passenger/instructional seat
10 pack front weights
4x90kg rear ballast + 2 x 455kg tot
advanced processor for GPS ready autosteer
high flow hydraulic pump
cab suspension
112" bar axle with cast iron dual rear wheels
4wd
120 volt engine block heater
dual hubs
16.9 R30 RT1W front tires
20.8R42 R1W P/NASO Gem FISSE Rears
Drawbar.
Dealers have me quoted about $112,000 - each dealer is plus/minus about $1000.
Have another dealer quoting about 108,000 but he has sold his dealership and cannot service it...so Im leaning away from him...but trying to get the others to match.
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
LOT LOCATIONS (A53426)
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
WOODS TBW15.40 LOT NUMBER 243 (A53084)
WOODS TBW15.40 LOT...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
