NT204C Temp Gauge Replacement?
   / NT204C Temp Gauge Replacement? #1
mstan99999
The Colony, TX
The lead wire for the temp gauge broke on my tractor. So, I called Affordable and was sent a new sensor. Turned out the gauge was broken too, so I called to get a gauge to match the sensor. As it would figure, my ignorance came screaming through again, because what I had on it was a mechanical gauge and what I purchased was an electric gauge. I was told that this was what I needed for my tractor and YM380 motor. Ok, so I now have both and have no real idea how it is supposed to be wired in. It came with no instructions and I don't want to kill what I have, so PLEASE HELP.
I purchased temp sender 309-T-A, as it was the "New Style" and my tractor is a 2003 model and that is what the guy on the phone said I needed. On the next phone call, I asked for and ordered what I was told is the gauge that is supposed to work with this sensor. I don't have a part number, but it is the only one listed on their website for the Jinma 200 series tractor, even though it is listed as "Old Style".
Here's where I am going to start speaking about what I know nothing about. I had an engineer neighbor of mine test the gauge for me and it seemed to work. At 100 ohms, it read 100 deg C, at 50 ohms, 90 deg C, at 25 ohms, 50 deg C. The apparent issue is that the sender is showing 225 ohms.
I don't know about you, but I'm lost.
The back of the gauge has a ground wire to the case of the gauge, two posts insulated from the case, and a lead to the bulb. The bulb is self explanatory, but how should the rest be wired in? Should this combination work? Any help would be appreciated GREATLY!!
Thanks!!
Matt
   / NT204C Temp Gauge Replacement? #2
I cannot answer directly to your engine as we have the NT254 (i.e. Y385 engine). However to get our digital temperature gauge we ordered this from Ebay (~$17)
Black 2" 52mm Blue Digital LED Fahrenheit Water Temp Temperature Gauge 7042 | eBay
To get the supplied sensor to fit we removed the existing fitting and sensor, then went to ACE hardware to find an adapter fitting to adjust from the new sensor to what the engine requires. The sensor we measured with calipers and the same with the previous plug the old sensor went into.. armed with that data we went to find a new plug that would adapt the new sensor the engine.
The new temp sensor works perfectly and is readable even in broad daylight.
2006 Ocmis 125 R4/2 (A50123)
2006 Ocmis 125...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
More info coming soon! (A50322)
More info coming...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
