Now the good and some differences
   / Now the good and some differences #1
catsco
Colorado
PT425
Now to repent for my mini-tirade of the 'delivery' experience.
First--some differences between Moss Road's PT425. I'm listing this as his is an earlier machine, and he's done a great job of documenting various aspects of the tractor.
-His has a plastic gas tank mounted in front of engine. Mine is steel and is a part of the cover, which places it above the engine and makes it hard to open the cover when full, and you can't easily tell what the fuel level is. Fuel could spill out, also, when opened. BUT, the battery is now where the fuel tank on MRoads machine is. Pretty convenient. Moss-Road--where is your battery???
-My engine mounting is reversed from MRoads. The exhaust is toward the front. Pictures to follow.
-The great debate regarding Command Pro vs. Command. Contrary to Scott's (Gentry) assurance that the Kohler 25 is a Command, the decal on it says Command Pro, it has the yellow cap, dipstick, oil sentry, oil cooler, etc. I think they just substituted the Command air filter for lower cost, and lower profile for the fuel tank that is now a part of the engine cover to clear it.
Other stuff--
There have been posts about the treadle sensitivity. It is sensitive, but my feet may have been made for Power-Tracs. By having a toe on each side of the treadle, modulation is easy, even on rough ground. It using just one foot at a time, smooth operation is difficult. Quick (and I mean QUICK!) stops are easy with one-toe at a time operation. /forums/images/graemlins/grin.gif
-Having the mini-hoe bucket curl as the separate lever is odd, but easily accommodated. I've read that some have considered relocating it or making a custom modification.
-I need to gain about 150 lbs. to use the generous seat belt! That's been well-documented in this forum. I have enough left over to make a shoulder belt. Hmm...
-ROPS seems sturday enough for the weight. Has anyone considered a separate ROPS for the rear part of the machine? There are holes in the bottom side plate behind the rear wheels. Just a thought.
-The exhaust routing and muffler insulation are interesting. I'll be cutting holes in the expanded metal where the dual exhausts (now comes out both side! More HP!. Woo-Hoo!) now spew INSIDE the engine compartment. Might have been better to slot the sides of the engine cover and extended pipes out.
-I haven't read the manual yet (Shame on me!), but the parking brake is counter-intuitive. That's why they couldn't figure it out at the freight terminal. RELEASING the brake seems to apply tension to the cables. I'm assuming that is to be a 'fail-safe' so the brake works even if cables part. I've discovered that it's very difficult to release the brake if the machine has drifted or been powered again whatever that mechanism is.
So--to make this not too long as I'm merely an owner, not an operator (or manual reader) at this point, I'll stop for now.
Pictures to follow.
The weather's better, the tractor's home, and will move to the property to do actual work within a week or two.
Mark H.
   / Now the good and some differences #2
</font><font color="blue" class="small">( I think they just substituted the Command air filter for lower cost, and lower profile for the fuel tank that is now a part of the engine cover to clear it. )</font>
Since your machine is configured differently than mine, it may have a different air cleaner. However, if I understand Kohler's parts provisioning correctly (not easy), there are two different low profile air cleaners. The Command Pro's is slightly larger. That is what I have.
</font><font color="blue" class="small">( RELEASING the brake seems to apply tension to the cables. I'm assuming that is to be a 'fail-safe' so the brake works even if cables part. I've discovered that it's very difficult to release the brake if the machine has drifted or been powered again whatever that mechanism is. )</font>
The brake pins are spring loaded. The friction brake lever holds them in the "release" position by pulling on the cables, as you found out. I think this is nothing more than a simple design. Since the brake is strictly a parking device and not an emergency device, I don't see "fail-safe" as being part of the design criteria.
The brake can certainly be difficult to release if any pressure has built up on the pins. The trick is to rock the tramming pedals ever so slightly while applying pressure to the brake handle. You soon learn to anticipate which pedal to use.
SnowRidge
Snowridge--
Thanks for the reply!
I appreciate the info.--all of us together might know what we're talking about.
By 'fail-safe', I meant fail-safe as in parking, not a service brake. The scenario (given my luck and skewed way of doing most things) that comes to mind is that if the cable fails, the machine will be immobilized rather than being able to drift.
Regarding the Kohler method - two of the local shops here are more baffled than I am about what is what. Apparently there are a lot of variations depending upon spec and serial #.
Not sure if that's continuous improvement or a 'dang, we should have done that different' revelation.
Mark H.
   / Now the good and some differences #4
Mark,
Congrats, and welcome to the PT family!
I am fairly confident you scored a "PRO" - you can check the spark plugs if you really want to - the PRO has different plugs.
As for me, given SnowRidge's experience (which he is really being a sport about), I would switch to synthetic oil (I'm using Mobil 1 10-30W) as soon as I could - I am also looking at putting oil pressure and cylinder head temp gauges in, as you can tell from another thread here.
Enjoy your new best friend and handyman!
Sincerely,
Rob /forums/images/graemlins/grin.gif
   / Now the good and some differences #5
<font color="red"> continuous improvement or a 'dang, we should have done that different' </font>
Is there a difference? /forums/images/graemlins/smile.gif
I'm going strictly by recollection and haven't looked at old posts, but it sounds as if PT cured a couple of problems/complaints. There were some posts about the battery being close to the exhaust, and the top of the battery getting hot. First, a new double exhaust reduced the heat. Now, it sounds as if the battery and exhaust aren't close any more, and the exhaust is still the PT type rather than original Kohler.
   / Now the good and some differences #6
</font><font color="blue" class="small">( There were some posts about the battery being close to the exhaust, and the top of the battery getting hot. First, a new double exhaust reduced the heat. Now, it sounds as if the battery and exhaust aren't close any more, and the exhaust is still the PT type rather than original Kohler. )</font>
Charlie -
I asked Terry about this a few months ago when the new design came out. I think PJ got the first one. Anyway - he said that the exhaust is still only a 'single' exhaust, and the other 'hole' is for air INTAKE. I'm just repeating what he said. From what I can tell, this is the same exhaust as on my 425, and I can definitely say that the exhaust only seems to come out one side.
Sincerely,
   / Now the good and some differences #7
</font><font color="blue" class="small">( Anyway - he said that the exhaust is still only a 'single' exhaust, and the other 'hole' is for air INTAKE. )</font> /forums/images/graemlins/shocked.gif
As far as I know, I get exhaust out both holes. I'll check as soon as I get the engine back and installed--whenever that is. /forums/images/graemlins/frown.gif
I do know for certain the muffler gets hot enough to torch off dry grass clippings. /forums/images/graemlins/crazy.gif We always check for this whenever we shutdown.
SnowRidge
   / Now the good and some differences #8
<font color="red"> the exhaust is still only a 'single' exhaust, and the other 'hole' is for air INTAKE </font>
Rob: You're right, of course. I should have been more careful. As I understand it, the system that was installed starting in the fall of '02 is intended to have fresh air in one side and out the other with the exhaust, which keeps the outer shell cooler. I don't know if the new one is the same.
   / Now the good and some differences #9
Mark,
Sorry to hear about the various trials and tribulations regarding the arrival of your new PT.
I only had one pallet to pick up from OverNight a few weeks ago, and it went very smoothly (of course I flew from Denver to NY and drove a rental truck back over 3 1/2 days to get my "new" PT to Denver, then dropped it off in Golden Friday afternoon during the snow storm, then drove back on Sunday to bring it the last 40 miles home after letting our mud county road dry out a bit.)
Looks like there were a number of seemingly needless frustrating issues associated with your new arrival. Hope that is all behind you now.
I also can not comment about the various differences between your 'latest-and-greatest' and the previous 'latest-and-greatest' versions of the 425, but it seems PT has generally made bigger steps forward than backward with each update. They also seem to make running changes as soon as they develop them rather than wait for new "model" years to come around. That is a good thing.
Glad to hear you are beginning to get comfortable with the operation and articulated steering and hydro system. I am sure your projects have been stacking up for a while so you will be putting it to good use right away.
Take a look at their recent price increases to cheer you up a bit. Just don't get run over out on 105 or 115!
Rip
   / Now the good and some differences #10
Charlie,
I, too, am going from recollection (a scary thought), but I think another complaint about the old battery location was the need to remove the muffler in order to acces or remove the battery. This in addition to the heat factor you mentioned. As always, I may be wrong.
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2001 TRIPLE E INDUSTRIES 48X102 TRI-AXLE STEP DECK (A52472)
2001 TRIPLE E...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
