Novice operating exerience....
   / Novice operating exerience.... #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
We bought a used Kioti yesterday. Today was the first time I operated a tractor and I played in the snow. All these things you have to do at the same time - steer, operate the throttle, raise or lower the bucket, turn the bucket up or down, and watch where you are going.
One thing I learned was what happens when you are backing up, looking over your shoulder, raising the bucket, and forget you are raising the bucket. Turns out that it goes too high and dumps snow backwards onto the hood of the tractor and splashes it back on you. Took a half second to understand what was happening. Luckily nobody was watching. :laughing:
Hopefully the rest of my errors will be as much fun.
   / Novice operating exerience.... #2
Good thing you were not carrying a bucket of firewood or rocks too!
We all have had similar experiences and they generally speed up our learning curve if we survive.
Good luck with your new Kioti. I've loved mine.
   / Novice operating exerience.... #3
Just take your time...learn all the safety aspects and learn good habits. Speed will come with practice and time.
As IslandTractor wrote, that bucket could have had stone or something a lot more destructive (to both you and the tractor) then snow. A raised bucket at the wrong time can also roll the tractor.
Be safe and enjoy your tractor!
   / Novice operating exerience.... #4
Wecome to the world of tractors. It would probably be better not to operate the bucket unless you can watch it. As you found out. Go easy and be careful. All your lessons may not be that easily learned. Lesson 1 - keep your bucket low as possible at all times. As Roy said a high bucket greatly enhances the chance for a roll over. The same is true of backing up because it is harder to see your angle w/o the hood and bucket in front of you for reference.
   / Novice operating exerience.... #5
Here is a few other safety tips. I have been keeping a list since I purchased my tractor.
Keep front/rear implements close to the ground, namely when going up hill
In neutral the tractor really moves going down hill, so keep it in gear and do not shift when going down hill, so plan ahead.
Be careful braking going down hill you can skid. If you are pulling something it could cause you to jack knife. Good time to be in MWFD if ground is wet.
If the front and rear tires are in a rut the tractor will move around to stay in the rut
If the bucket is on the tractor keep the blade up, this way if bucket runs into the ground, the tractor may ride up on the bucket instead of the bucket digging into ground and maybe stopping the tractor and tossing the operator off.
Think ahead of what you are going to do, the tractor is powerful and is unforgiving. If you think you need MWFD, put it into MWFD ahead of time, since some tractors need to be stopped to put it into MWFD.
Keep roll bar up and seat belt on. No good to have roll bar up, if you are not wearing your seat belt
As you raise loader you need to lower bucket to keep it level
As you lower loader you need to raise bucket to keep it level
Be careful raising the loader near something as the bucket moves out a little as it goes up.
When bush hogging watch that something does not get caught in the lynch pins and pull them off.
When loading on a tow behind trailer, make sure as driving tractor on the trailer
   / Novice operating exerience.... #6
You said you are operating the throttle. Tractors are not like cars, you set your throttle once and typically do not touch the throttle while operating. Tractors have a governed throttle and the engines are designed to operate continuously at 2000 to 3000 RPM.
In your car if you are cruising on level ground at say 2000 RPM and you start up a hill the RPM will drop unless open the throttle. With a tractor when you set the governed throttle to a specific RPM, it will automatically open the actual throttle to keep the engine at the set RPM.
Speed is controlled via the HST pedal or in the case of a geared tractor, selecting the appropriate gear.
   / Novice operating exerience.... #7
New to forum...what is MWFD?
Thanks.
   / Novice operating exerience.... #9
Thanks.
Mechanical Front Wheel Drive. For practical purposes think of it as four wheel drive but it is not exactly the 4 wheel drive you think about with Jeeps or bigger tractors. None of the CUTs have true 4wd that I know of.
   / Novice operating exerience.... #10
you learned a valueable lesson about raising your loader to full hight with the bucket tilted all the way back.i set my tilt on the bucket or hay forks an leave it alone.an i never fully tilt the forks back unless i have to,an even then never with the loader all the way up.because the bale could roll down on me an kill me.
2015 3500 HD Chevrolet Ambulance (A52377)
2015 3500 HD...
2004 TerraGator 8104 (A53473)
2004 TerraGator...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
