Note to self.
   / Note to self. #1
Bud Soda
Platinum Member
NC
Ford 5000, 3000
Never put too much grease in the center pivot joint on the front axle of a T 2337 :(
   / Note to self. #2
Bud, Please tell us what happens when someone puts too much grease into the center pivot joint on the front axle of a T2337.
Thanks,
John
   / Note to self.
I pumped a hand grease gun six times and it pushed the pivot bushing off the end about two inches and bent the flat steel support bracket that the pivot mounts to. I had to take it apart. and straighten it and then put the bushing back in the center pivot.
   / Note to self. #4
On my tractor, (Kubota L3830), you are supposed to unscrew a grease release plug located on the outside of the axle/pivot housing to release any pressure as you pump new grease in. I pump a little in and a little comes out the plug hole. I would guess your tractor would have a grease release plug, too. Check the owner's manual...I'll bet it will be there.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
