Not enough rear remotes
   / Not enough rear remotes #1
jeffxjet
Trenton, Texas
JD 5055D
As per my thread in the attachments forum I just picked up a hyd. box blade and would like to add a TNT to adjust it. I have a JD 5055d with one set of rear remotes that I use now to move the scarifiers. What do I need to do in order to add a second or third set of rear remotes? I looked at what I think is the hydraulic pump and the rear remotes seem to come directly off the pump.
Here are some photos of where the power comes from. The wrapped hyd lines go to the loader on the front, the painted green lines run to the rear.
   / Not enough rear remotes #3
From your picture, it looks like a SCV (selective control valve) with the two steel lines to the rear couplers. You should be able to verify this by checking the forward area of the valve for linkage to the operating lever.
Then bolted to the SCV is a Power Beyond block with hoses going to your mid mount loader valve.
If I am correct on these two items, I think all you need to do is buy another SCV and mount it between the current SCV and the Power Beyond block. You will need studs and nuts or longer bolts, linkage and a lever, lines, couplers and a bracket for the couplers. JD may offer a 2nd SCV bundle that will include all these parts and install instructions.
You might find a 2nd SCV bundle listed in the "build your own" on John Deere's website. Look for Field installed items. That would give you a part number to take to the dealer for a price or to order.
Thanks for the help guys. Zebrafive, I believe your assement is correct, the operating lever is connected to that.
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2022 Cub Cadet Ultima ZT1 54 in Lawn Mower (A53117)
2022 Cub Cadet...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
John Deere D105 Auto Riding Mower (A53117)
John Deere D105...
Informational Lot - Financing (A53473)
Informational Lot...
