Norwood Log Hog 3PT Skidder vs boom
   / Norwood Log Hog 3PT Skidder vs boom #1
Maynah13
Central Maine
JD 750
I'm trying to decide if I can safely skid logs with a boom pole, or should I go the extra $$$ for a 3PT skidder attachment called the Log Hog
Anyone have experience with one of these? I've read some posts where people have used a boom pole without a problem, yet others have warned it might be unsafe, due to the high center of gravity. I only have a little JD 750, so I don't plan on skidding giant sequoias.
   / Norwood Log Hog 3PT Skidder vs boom #2
I'm going to advise against the boom pole. Its length causes it to act as a huge lever, increasing the weight (theoretically) of the logs you are moving, and, as you have stated , raising the center of gravity. Your tractor will be wanting to flip over backwards as it is..... nevermind having the logs hook up higher and farther out off the back of the tractor. The Northern Tool attachment actually looks fairly affordable to me.
My thoughts exactly. The Norwood unit is about $100 more than a boom pole ($200 more than I could build one for), which is worth the piece of mind, assuming it doesn't have a similar problem.
   / Norwood Log Hog 3PT Skidder vs boom #4
Both of these guys are right. Center of gravity and then pulling makes the boom pole wrong. This unit would work better, always keeping it as low as possible. Somewhere I saw a pull behind 2 wheel cradle for skidding logs with smaller tractors and ATV's. Right now I can't remember where, old age working! But it would always be pulling the load from the drawbar. If I can find it I will post, maybe someone else knows what I'm thinking of.
   / Norwood Log Hog 3PT Skidder vs boom #6
Yep. The Harbor freight quick hitch will help keep the log low. Just hang the chain from the top hook for the lifting. Drop a drawbar (or rebar) in the lower hooks to keep the end of the log from bashing your PTO guard.
You can chain to the drawbar for the pulling, thereby reducing your chance of rollover.
God I love this web community! :D
A quick hitch? Ya know, it kind of resembles the log hog but a lot cheaper. Good idea worth considering!
With the price of oil, a lot more people are turning to firewood. Unfortunately, this will mean more accidents. I don't plan to be one of them.
   / Norwood Log Hog 3PT Skidder vs boom #8
Here is my old JD750 set up to skid logs off my lot. Tongs, 2" receiver with D ring and 3pt 2" receiver. Worked well.
Did you have to add any front weights? Looks pretty efficient.
   / Norwood Log Hog 3PT Skidder vs boom #10
My 750 had a front end loader so I didn't add any weights. Mine was 4wd/FWD also, so the front axle added some weight.
Box Blade Pull-Behind Tractor Attachment (A51691)
Box Blade...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2016 PETERBILT 389 (INOPERABLE) (A53843)
2016 PETERBILT 389...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A51692)
2015 Ram 5500...
