DUMMASS
- Joined
- Aug 20, 2012
- Messages
- 41
- Location
- PHELAN ,CALIFORNIA
- Tractor
- NORTRAC NT-204C /Jinma Y380 engine
HOW DO YOU DETERMINE WHY THE TRANSFER CASE ISN'T INGAGING?
HELP PLEASE
HELP PLEASE
THANKS RON,
REMOVED COVER EVERYTHING SEEMS TO BE FUNCTIONING CORRECTLY..........NOW WHAT?
Guess you forgot about the time I had to rebuild the transfer case on my KM454. The transmission front drive gear and the transfer case driven gear chewed each other up and bent their respective shafts in the process. All four pieces had to be replaced, along with the associated bearings and seals. It was a 2wd tractor for quite a while before I got all the parts together to tear it down and fix it.I all the cases of the front wheel drive not working that I've read about on this and other forums, I've never yet seen one that was the result of a failure inside the transmission or the transfer case. .
