Nortrac NB3500 Dozer
/ Nortrac NB3500 Dozer #1
Tomdatermite
Hope someone can help here. I was using my dozer last week and had a small branch get under the hood. It had snatch a blue wire out of a terminal but I can't figure out where that terminal is. The wire pulled free with the lug still attached. If the wire had broke wouldn't be no problem locating. Anyways this blue wire runs down the left side underneath the hood along side the hood stand. Comes out of a harness beside the fuel tank.....from what I can feel, just can't see. If someone could tell me where to attach this lug back to under the hood sure would appreciate it. Thanks.
/ Nortrac NB3500 Dozer #2
If ya all got a wire off then something is not working, should be able to narrow that down pretty quick.
/ Nortrac NB3500 Dozer #3
You would think something should have quit. Doesn't sound like a ground wire as it is color coded. Can you get a wiring diagram off the net ?
/ Nortrac NB3500 Dozer #5
That wire goes on a sending unit that is located between the two fuel injectors at the rear of the engine.
/ Nortrac NB3500 Dozer #6
this post is 2 years old
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Hanson SB-72 3 Point Snow Blower (A65640)
Hanson SB-72 3...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
2023 Kubota Z232 (A64127)
2023 Kubota Z232...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
