nortrac dozer
   / nortrac dozer #1
coreyq
chariton ia
nortrac
Hey guys new member here. I've got a nortrac/yuchai rubber track dozer and I'm looking for info on the proper track adjustment. Any info would be much appreciated
   / nortrac dozer #2
:welcome:
To the forum Corey. I am sure that someone here will be able to help. Just might take a day or two.
   / nortrac dozer #3
Might want to try to post in the Chinese tractor section. There are some posts on these dozers over there.
   / nortrac dozer #4
Welcome
   / nortrac dozer #5
Measure From the top of the track frame to the middle part of the track in between the top roller and front idler. Usually 2.5 to 3 inches of sag on most dozers are good. Just don't get them tight. You can blow out the track adjuster or brake the track in half.
   / nortrac dozer #6
An inch of sag is plenty unless you are on muddy ground. To much sag and the tracks will flop off, to tight and it will bugger the idler bushing.
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
UNUSED 2-Pack Yellow Outdoor Patio Fabric Screen (A50860)
UNUSED 2-Pack...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
