NorTrac 204C New to me
   / NorTrac 204C New to me #1
New River
Nor Trac NT204C
Hello everyone perhaps you can help, I've got a stupid question.
I purchased a 2004 NorTrac 204C super low hours from original owner.
I have the owner & part manuals but I'm trying to locate fuel lines and parts (the Arizona sun and heat did a job on these lines).
When I look under Circle G Tractors under the Nortrac 204 and 204C it list the engine models: 295T, LL380, TY290, TY295, Y380, which one do I have?
The manual says its a 204C, has the 3 cylinder diesel 20 hp, 4wd and the parts numbers for the fuel system are: YJY, YJP, YJT.
Again stupid question, so someone please point me in the right direction,
Thank you
   / NorTrac 204C New to me #2
Look at the engine ID tag to see which engine you have. It may be on the block or it may be on the valve cover.
Which fuel lines do you need to replace? I have had good luck with carefully cutting through the crimped sleeve at the connector and removing the old line. The connectors are barbed so you can buy fuel line and small hose clamps and put it all back together.
   / NorTrac 204C New to me #3
Thank you both.
So Affordable, if I have the part number in my service manual, is there a conversion sheet to determine which line can be purchased?
Also I see a Y380 and a Y385T but no Y380T in the parts section.
   / NorTrac 204C New to me #5
We have a parts manual for the Y380T engine, the fuel lines changed from hard lines to Stainless steel flex lines several years ago, there is no cross reference anywhere unfortunately,we keep them by length and size banjo hole on each end.You must have that info to get the hoses, if you do not have a caliper to measure now is the time to get one with a Chinese tractor, Harbor freight has them for $ 20.00 .Most hoses are 12mm to 14mm ends
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-865-4002
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
