gotago
Has anyone bought the northern tool cat1 pto log splitter thats $399 for use with the PT? I thought about buying the splitter and just mounting it on a pallet for use with the pallet forks. Any thoughts?
gotago said:Has anyone bought the northern tool cat1 pto log splitter thats $399 for use with the PT? I thought about buying the splitter and just mounting it on a pallet for use with the pallet forks. Any thoughts?
Have you looked at strays posts on his log splitter for his pt? His design is the slickest design I've seen.gotago said:Has anyone bought the northern tool cat1 pto log splitter thats $399 for use with the PT? I thought about buying the splitter and just mounting it on a pallet for use with the pallet forks. Any thoughts?
gotago said:Thanks Moss, I plugged in the numbers, anyone care to check them? 25 hp at 8gpm = approx 2250 psi. For a 4 inch cylinder with a 1.5 inch rod at 2250 psi and 8 gpm I get a push force of approx 28000 lbs at 2.5 inches per second push and 2.9 inches per second retract. For some reason I had it in my head that the pto produced greater than 2250 psi. If these numbers are correct then I think i'll shop for an 18 or 20 inch cylinder. Seems like a 24 inch cylinder would have an overly long cycle time. Any thoughts?
