Normal Play at FEL cutting edge
   / Normal Play at FEL cutting edge #1
Hodgewater
Canada
BX25D1
I have a Kubota BX25 with about 80 Hrs. Lately when I start to lift the bucket there is a delay from the time the arms move before the bucket moves. I raised the bucket and can rock the bucket, a inch or two at the cutting edge. Some of the play is in the pin at the top of the cylinder. Is this normal?
   / Normal Play at FEL cutting edge #2
Have you ever greased it?
How much of the play is in the pins and how much is in the cylinder (rod moving in and out of the cylinder). Play in the cylinder would be air in the system. Does your loader valve have regen? If so, use that when dumping and it will keep the air out
   / Normal Play at FEL cutting edge #3
I have about one inch of play - half inch up/half inch down. Mine is all in the pins and arms - not in the hydraulic cylinders. I grease mine at least monthly.
   / Normal Play at FEL cutting edge #4
Check your hydraulic fluid level- that can slow things down if you are low.
2006 CATERPILLAR 252B SKID STEER (A51246)
2006 CATERPILLAR...
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
