Normal Operating Temperature
   / Normal Operating Temperature #1
Coachnic
Suwanee, Georgia
Mitsibushi D2050
What is the proper operating temperature in degrees for a Mitsubishi D2050FD? I recently put a numeric temp gauge in on the tractor but can not find in manual anywhere about the normal operating temp. Is it 200, 225, 230 or 240 degrees? Thanks, B Nic
   / Normal Operating Temperature #2
I've got a D1850FD and during this years low 90s, the mechanical temp gauge pretty much stayed at 210 when I was bush hogging. I always make sure the radiator is clean before I start, and I'm running a 50/50 antifreeze mix
Thanks again Gunny. Headed down this weekend and going to give her a full tune up with filters, oil change, new filter assembly and going to flush the radiator with Napa radiator flush and add back with 50/50. Just curious, do you add any fuel additives to your tractor?
   / Normal Operating Temperature #4
The only thing I add to my diesel is Super Tech TC-W3 2 cycle motor oil (200:1 ratio). I started doing that not long after the ULSD came on the market, to give a little more lubrication to the injector pump.
I did it based on this study: Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
On the temps, what I should have said was that my tractor doesn't get over 210 degrees when bush hogging in hot weather. Don't know why I wrote that it stayed pretty much there. I did my fall cutting last week (weather in the high 80s) and it usually held at 205.
I really like this little tractor and since it's getting harder and harder to find replacement parts for it, I try to keep an eye on everything and not stress it out anymore than I have too.
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
More info coming soon! (A53421)
More info coming...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A53424)
Year: 2017 Make...
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
