Normal Operating Temp for a 3525?
   / Normal Operating Temp for a 3525? #1
Etch
Bronze Member
San Antonio, TX
Mahindra 5155
Just curious as to what temp you 25 series tractor owners are seeing. The green part of the gauge reads up to around 235 and there is a tick in the middle that reads 221. I'm usually running around 221 or just over.
   / Normal Operating Temp for a 3525? #2
I'll be on it tomorrow and I'll let you know.
   / Normal Operating Temp for a 3525? #3
I don't know about late model stuff, my 5005 runs around 190 when I am really working it, and around 180 just tossing hay bales around. I am not a fan of any diesel engine running over 210 for any length of time. Sometimes I think those "green" areas on guages are there for looks. The temp guage on my 97 6.5TD chevy doesn't show red until 260 and I think that would be way after something melted and ran out the exhaust pipe.
   / Normal Operating Temp for a 3525? #4
Maybe I'm looking at it wrong but I thought the 221 was at the end of the green part. My temp guage read about a 1/16th over the middle line. Well below the end of the green scale.
   / Normal Operating Temp for a 3525? #5
Hey Etch, and others with a 3325/3525...
How slow is first gear? Is it slow enough to use a rotary tiller with the tractor? On the 3325, how is the manual steering? Is it pretty light, or is it more heavy steering?
I've got a 52 Ford 8N that I'm just about fed up with (for the past 6 years)... and the 3525 looks like just the ticket for me. I'm leaning toward the 3525 because of the hydraulics and power steering, but a 3325 would fill the bill for me also... except that I'd like to possibly add a fel down the road.
I grew up on a dairy farm, and have been driving tractors since I was old enough to reach the pedals... and even though I don't work on the farm anymore, I know that this tractor will surprise most people with how much it will pull... 4wd helps, but isn't mandatory. I'll mostly be mowing my 5+ acres of grass, bushhogging the remainder, and then hauling firewood, skidding logs, plowing, etc... all the stuff you use a tractor for! :)
1st gear is pretty slow, so I don't think you'll have any problem tilling. The power steering is great and the wheel is super easy to turn. Not sure how it compares to the 3325 without power steering, but I'm glad I got the 3525. If you plan on adding a FEL, you should just go with the 3525. I was originally going to go with the 3325 until the dealer said it probably wouldn't handle a FEL.
So far I'm loving the 3525. It has handled everything I've thrown at it so far. I've bush hogged about 8 acres or so, cut a 6ft wide drainage ditch, spread and leveled three 13 ton piles of top soil, cut a narrow ditch with my mid buster, resurfaced part of my gravel driveway, etc.
You know, maybe you're right. I was thinking the 221 was the break in the green area, but now that I look more closely at it, it does look like it is the top end of the green. That makes me feel better!! And usually I'm running around the same temp as you, just over that break in the green area.
   / Normal Operating Temp for a 3525? #8
Hey Etch - did that cover come with your setup or was that something that you added on. I could kick myself in the "arse" for not getting a cover to block out the sun. I looked on the Mahindra site and don't see it offered anywhere.
   / Normal Operating Temp for a 3525? #9
The way my dealer told me was that a FEL could not be added to the 3325 because it doesn't come with power steering. Didn't get into much detail as to why. I was actually looking at the 3325 but needed one with the FEL.
It was an option. When I bought the tractor I asked if they had a canopy to add on. It was $350 I believe. It is definitely nice having and only becomes a problem when getting close to trees with low branches. The canopy is made of fiberglass if I'm not mistaken. It's a must have when cutting acres and acres of grass under the hot Texas sun in August.
As for the 3325 and FEL, that is what the dealer told me as well. Probably too much weight in the front for you to be able to turn the wheels while carrying the FEL, not to mention the dirt/gravel in the bucket.
2002 GREAT DANE 102" X 53' T/A VAN TRAILER (A51243)
2002 GREAT DANE...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51243)
CASE IH 580...
International 820 Platform (A50514)
International 820...
2014 JOHN DEERE 17D EXCAVATOR (A51242)
2014 JOHN DEERE...
(2) SODA FLO CONTAINERS (A51244)
(2) SODA FLO...
