Non standard dash switch mounting holes
   / Non standard dash switch mounting holes #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
I have a MT240 and it has 5 blanks of the dash for toggle switches.
The problem is that the cut outs are not the standard 21mmx37mm, they are taller so standard switches do not lock into place, as there is a small gap top to bottom. Side to side is OK.
Has anyone found a rocker switch that fits the factory cut out?
I was looking to add LED light bars and such.
   / Non standard dash switch mounting holes #2
You need a switch that's 1.734 x .867 in [44.0mm x 22.0mm]. This is a standard size however most aftermarket sell the smaller size switches.
Carling L series fits the holes and are the brand that's found on the tractor.
Try this site.
thanks, I appreciate the info. Those are prefect, you can even have custom text created.
Goosen Versa-Vac Turf Vacuum Tractor Attachment (A49346)
Goosen Versa-Vac...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
ASV Posi Tool Backhoe Quick Attach (A48837)
ASV Posi Tool...
2021 CATERPILLAR 299D3 SKID STEER (A50458)
2021 CATERPILLAR...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A50046)
2018 FREIGHTLINER...
2015 Ford F-150 4x4 Pickup Truck (A48081)
2015 Ford F-150...
