Front-End Loader Non-current loader parts?
   / Non-current loader parts? #1
katesaidan
So I have a wonderful (/snark) JD 790 CUT that I got with our house, included with it was a Bush Hog mower and a JD 70 front end loader. To say the tractor is in poor shape is an understatement. We have replaced the battery, need to replace the connectors for the batter, the two front tires had to be replaced because of dry rot and the rear tires are going the same way.
The front end loader is missing one of the quick release rods, and I can't get a replacement because JD is apparently not making parts for this front end loader.
Of course one of the hydraulic hoses blew (dry rot, of course). We picked up replacement hose at TSC and of course the hoses do not fit. I checked JD parts and they have NO parts available - at all - for the JD 70 front end loader.
I REALLY need some help here - we need to get that line replaced so we can use the front end loader. The hose that blew is the one that allows the bucket to tip down. If JD isn't making the parts (and the JD parts site isn't offering a substitute) what am I supposed to do?
If there is a technical name for this particular hydraulic line I'd love to know it - google isn't being particularly helpful in this endeavor.
:mad:
   / Non-current loader parts? #2
I'm guessing the hose you bought at TSC has NPT ends and the loader takes something else? Just take the old hose to your local hydraulic shop and have one made up. It will cost a couple of times more than the TSC hose so be prepared for that. Even our local car parts stores can make up hoses here. Another possibility is to buy adapter fittings to get from the NPT hose end to whatever the loader has. One end will need to have a swivel. Can't help you with the quick release rod other than that you have a pattern from the other side. Is it something you can make? If not, I'm sure a welding or machine shop could.
Kim
KUBOTA L4600 TRACTOR (A51243)
KUBOTA L4600...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
