noisy power stering
   / noisy power stering #1
claytonalder
ontario CANADA
dk 35,david brown 990 red
The last couple off times i have used my dk 35 i noticed that after i have worked the tractor the power steering starts to
wine. It seem like it can't find its neutral .If i turn the wheels i can make it stop if i hold it in a certain spot.It makes no noise when i first start it up . Is their an adjustment for this.
It seem like once the hydraulic fluid get hot this noise starts.
thanks
clayton
   / noisy power stering #2
My 50c does this too ..will be watching and hoping for replies
   / noisy power stering #3
</font><font color="blue" class="small">( The last couple off times i have used my dk 35 i noticed that after i have worked the tractor the power steering starts to
wine. It seem like it can't find its neutral . )</font>
I haven't had this problem exactly, but I have noticed that if hydro levels are not just right, there can be extra noise when turning all the way one way of the other. I had the problem after using the BH and losing some fluid when changing. The level was down not too far, but when I filled it up, I didn't get the noise any more. Also, I made sure the filters were cleaned or replaced. If there is any restriction in the system you can get noise. I don't know if this is your problem, but I hope it helps. John
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2016 Nissan Frontier Extended Cab Pickup (A50323)
2016 Nissan...
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
KUBOTA U55-5 EXCAVATOR (A51242)
KUBOTA U55-5...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
