I hope someone has an easy solution to this one.
I have a thumping with a very slight rattle noise coming from the driveline of my 224 tractor. It gets louder as the tractor warms up, sounds like it is coming from the front end of the tranny at the creeper box area. It is their when sitting still or moving. I took the creeper plate off to check it out inside and cant see any thing wrong. From what I could see all the teeth were on the gears. The sound goes away when the clutch is pressed. What I did find out is the sound is only there when I put the creeper selector in high as there is no noise when in low creeper. Does this eliminates the clutch as the problem. Therefore it seems to be associated with the creeper high range setting. Other selections like 2 or 4 wheel, different gers ranges or high low range do not effect the noise.
Does any one have any thoughts on what to check next?
