noise in jcb backhoe.
   / noise in jcb backhoe. #1
neco
seminole, Florida
gcb backhoe 84
jcb, backhoe with turbo and 4x4, 84 year , after having it parked for about a year because the starter couldnt be removed, it startet instantly again, but in neutral it makes anoise, noise increases when moving forward, but sounds normal in reverse, noise goes up also when increasing revs. is it because of water or air in the hydraulic system? the hydraulic tank did not have a cap all this time and i suspect some water got in, how to empty the whole system if this is the case, can i use it like this, it has lost some of the power lifting
   / noise in jcb backhoe. #2
:welcome: to TBN!
The oil should be milky if there is water in it. Losing lifting power would suggest flow restriction, I would change the filters at a minimum. If the oil is milky its time to go. Do you know how many hours are on the oil? Most tractor manufacturers recommend you change hydraulic oil every 400 hours.
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
