Oil & Fuel Noise behind oil filter. What could it be?
   / Noise behind oil filter. What could it be? #1
gt14
Aumsville Oregon
Yanmar YM146 YM165D
I have a strange noise coming from behind the oil filter. The noise sounds like a bearing rotating around. It is loudest when I first start the tractor a YM146 same as a GT14. Before I get into it I would like to know if anyone else has had any problems like this. I also have a voltage regulator problem. I have fried 3 of them and the battery never charges. Does anyone know a solution or a workaround, maybee using a alternator instead of a generator?
Thanks Dan
I still haven't figured out what the noise is. It only happens when the tractor first starts and continues for 3-4 minutes. I sounds like a whirling noise and it is coming from the oil filter.
   / Noise behind oil filter. What could it be? #3
Have you by chance tried changing the oil filter? I'm wondering if it's a faulty bypass valve in the filter that is making the noise. When the oil starts to warm up it get thinner, pressure drops and the noise goes away. It's worth a try changing the filter if you have not done so yet.
Thank you I will try that.
Vermeer BC1800A Wood Chipper (A51573)
Vermeer BC1800A...
LOT NUMBER 246 (A53084)
LOT NUMBER 246...
Electric Concrete Mixer (A51573)
Electric Concrete...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
