No Start
   / No Start #1
Wrenchman
Hi guys, new to the forum. I have a 1978 Iron Mule with a Ford 3 cylinder diesel. I believe the older mules had a Massey Ferguson tractor front end on them (correct me if I'm wrong). The problem that I'm having is a no start in cold conditions. I don't believe the older Ford diesels had glow plugs on them, which make things worse. Any ideas on how to start this thing? Thanks!!
   / No Start #2
Welcome to the forum.
Could be a number of different things. Fuel, worn engine, glo plugs as you mention.....
But adding heat would/might be the best solution.
Maybe keep it inside, and leave a vehicle outside that will start.
Or put a heating element on it somewhere that will heat the engine.
My Deere wouldn't start this morning. Dropped the filter bowl off, dumped the contents out, wiped it out (didn't have a new filter to put back in :( ), put it back on and fired right up. Cold temp was about 10 degree F in the shed. Negative 5 degree outside. Have glo plugs, but rarely swithch them on.
   / No Start #3
Ford engines had thermostart it has a plug in the manifold with a wire and small fuel line going to it,if yours does not have one then the only other solution would be a block heater.
   / No Start #4
My John Deere never starts in the cold so I put my battery charger on one of the batteries and put it on quick start and it always fires right up.
   / No Start
Thanks guys...I'm going to have to try and get it inside somehow.
   / No Start #6
There are several ways to heat a diesel to make it start easier and faster.
Add a lower radiator hose heater, you can buy one at NAPA. Make sure you have a good location for it though...my MF 1010 didn't. The radiator hose had no good place to put one in.
Remove a freeze plug and replace it with a block heater. These seem to be the best thing going if you really want to warm it up.
Or do what I did and fab up a DIY engine heater with a heat lamp bulb (Ace hardware, about $5.00) in a metal fixture that you can slide under the oil pan. Put it on a lamp timer so it comes on a couple hours before you want to start the engine. This works best in a garage of course, so it's not affected by the wind. But it works very well.
Good luck.
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
2011 Kubota R520S Articulated Wheel Loader (A51691)
2011 Kubota R520S...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2009 Pontiac G6 Passenger Car (A51694)
2009 Pontiac G6...
TRUCKING INFO (A50775)
