No sound on computer
   / No sound on computer #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Need help to get sound on computer with windows 7. Press button symbol on screen shows no sound. The big red x.:confused:
   / No sound on computer #2
Hard to troubleshoot via a forum but start with the simplest and work your way into the computer shop.
Speaker audio chord plugged in and speakers powered up
Mute not selected and volume turned up for all audio inputs
Check to see none of your audio drivers are "x" out reload if they are.
Good Luck
Good Luck
How do I check drivers?Help check says audio driver enabled.
   / No sound on computer #4
Just an observation based on no knowledge ...
Is this a new computer? did you previously have audio?
if the audio is integrated (not a separate sound card) you will need to use a set of speakers that have their own amplifier...with independent power source...
If you just have speakers plugged in...the output from integrated audio is most likely not strong enough to power the speakers
Try using a set of headphones...
Yes newer but I've had it for 4 months. Yes had sound,Seems I can't turn it back on by hitting the mute button.
   / No sound on computer #8
Is this a laptop? desktop?...brand and model ?
   / No sound on computer #9
volume turned down in the mixer / master section?
HP Pavillion dv6-6c54nr laptop.Have tried restart. Mute button seems not to work as it just shows speaker and volume icons on screen but bottom of screen icon has red x on speaker.
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
2012 PJ Trailers PJFS25 25ft T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
Peterbilt 377 Semi-Truck (A56435)
Peterbilt 377...
XCMG CV83PD (A53317)
