No PTO output
   / No PTO output #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I have been running with the PTO in neutral. I need the PTO and cannot get it to shift to either speed range. The shift lever Only appears to go from 540 to neutral but the PTO shaft turns freely by hand.
All suggestions welcomed.
   / No PTO output #2
I got no valuable advise about how to fix it.
The only thought I have is the danger of messing with the PTO shaft with your hand, especially while its engaged or trying...
I'm sure you already know that. Just can't help but remind. :)
If that sucker engaged unexpectedly... I hate to think.
Sorry I got no other advise.
Sent from my iPad using TractorByNet
   / No PTO output #3
Checked that the shift lever is moving the shaft into the transmission? Sometimes there are a pin that snaps
   / No PTO output #4
There should be 2 controls for the PTO. One is the speed control that you mention. The other is for engaging/disengaging the PTO. On my Jinma 284, it is located to the left of my right foot and is pushed down for PTO engagement.
   / No PTO output
It was the Lever inside my right foot. After engaging it I pushed the RPM lever up to 540 and all is well. I don't use the tractor very much but when I need it I need it.
Thanks for all the helpfull replies.
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
