No power
   / No power #1
mikoli007
Tuttle
2006 ASV RC100
Good day. I have a 2006 ASV RC100. Worked fine until starter went out. I had to remove two rear cab pins to raise up the cab enough to disconnect the battery to remove the starter. Replaced the starter, hooked it all back up, reconnected the battery and no power. I have a new battery connect to the outside battery post. Checked all fuses and even installed a new 80 amp main power fuse only because it was slightly discolored. I do not know how to remove the main power relays ( they are not the simple pull out kind). There are three red wires (two thick and one smaller) a white and three black. I connected the three red to the left or big post on the solenoid and the small white to the small post on the solenoid and the three black to the starter post. Did I hook up the wires wrong? I forgot to take a picture because it seemed so straight forward. Could the switch have gone out?
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
