no power to 4410
   / no power to 4410 #1
wango tango
Peoria IL
i went to start my 4410 this Am. it turned over once, then stopped. NOTHING works. no lights, etc. no clicks from solenoid. it has a relatively new battery (1.5 yrs old).
is there a fuse or something i could check? i haven't been able to do anything as i was late to work. going to look at it tonight.
   / no power to 4410 #2
Just because it's a relatively new battery doesn't mean it's not a dead battery.
The first thing to do is jump or charge the battery and see if it cranks over. If you may jump it from another vehicle, you may have to let it charge off that other vehicle for a while. The headlights should come on, even if there's not enough cranking amps. Try that, but don't leave them on.
BTW, while you're hooking up the charger (or jumper) cables, make sure the tractor's battery cables are corrosion free and tight.
Repost (or PM me) after you try the jump.
   / no power to 4410 #3
I'd suggest to check ALL FOUR battery cable connections.
   / no power to 4410 #4
Yep..and to clarify...Tx Jim means both ends of those cables (battery connection and starter (hot cable), frame ground (for the ground cable)).
Check (visually, as best you can) the integrity of the ground cable. Although not too likely, I've heard of those cables deteriorating.
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2019 RBR Venturi 380 (A53473)
2019 RBR Venturi...
FLOOR JACK (A53843)
FLOOR JACK (A53843)
