No power, saggs after 10 seconds of load.
   / No power, saggs after 10 seconds of load. #1
olinrc
to20 ferguson
To20 Ferguson
Fixed this problem, The friction washer between the valve stem and the rocker arm had slipped over about 1/8 inch trapped between the rocker arm and valve stem not allowing the valve to close. I found this with a compression gauge, number 3 cyl. Tapped it back in place and adjusted the clearance. After mowing 20 acres it has happened again. Is the permanent fix new parts?
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
Bushog 6ft Disk Mower (A51573)
Bushog 6ft Disk...
2024 JOHN DEERE 35P LOT NUMBER 110 (A53084)
2024 JOHN DEERE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
