No lights, lost manual, and now insane owner
   / No lights, lost manual, and now insane owner #1
Farmwithjunk
Super Member
Mt Washington, Kentucky
Where do I begin.....
Got a problem. The bright lights on the right fender of my Massey Ferguson 150 went out last night while feeding cows. Not a problem! Or so I THOUGHT.
I THOUGHT it would be a simple "get out the meter and trace the problem" issue. No such luck. I tried everything I know to jump wires around the factory wiring to power up the lights. Nothing works. The dim lights (one of the two headlights on each fender) work. When I go to bright, they both go off.
OK, get out the shop manual. Let's see? Where did I put it when we moved? It's not with the rest of my manuals..... OH YEAH... Now I remember, I loaned it to my cousin, who's now in Japan on vacation.
Long story short, I'm obsessing over these lights. They GOTTA be working. Does anyone have a shop manual for the 135/150 that they could copy the wiring schematic and fax me a copy? If so PM me and I'll get you a fax #.
Anyone have a clue what I'm dealing with here? (My personal opinion is GREMLINS) (Yes, the bulbs all light when swapped to the other fender.) I suspect a ground problem, but so far can't find it. This is a relatively simple wiring harness, so it CAN'T be too difficult. (Famous last words)
Thanks,
In the dark.
   / No lights, lost manual, and now insane owner #2
I'm with you ,sounds like a bad ground to me, in the phone business we would call something that works like that a leaky circuit. It works somewhat until you put a load on it, Then the ground isn't sufficient to pass all the current/thus shunting it.
Set volt ohm to hi resistance setting and check all connections
,check through switch ,chassis ground ,lamp ground,you will find it. I would disconnect battery for true readings just so I don't get false indications across terminals. Meter should peg for a solid ground short if it doesn't there is too much resistance...sometimes broken/fraid wires at terminals may look ok but aren't good enough to pass current... If you already know this forgive me for being so yacky /forums/images/graemlins/crazy.gif just trying to help...
Also if you haven't gotten any further or better help, I have a manual for the 135 at home if need be. /forums/images/graemlins/cool.gif
Let me know and I'll try to help you out later this evening...
Edit: Are these bulbs in a socket or do the bulbs have prongs for a plug? If a socket , the sockets probably the culprit..look inside the socket for corrosion or contact with ground.
My extent of electrical knowledge is this;
1. OFF
2. ON
From that point on, anything you can tell me is more than I already know.
I got the friendly local AGCO (MF) dealer to fax me a copy of the wiring diagram this morning. It's more or less what I already thought. No real revelations there.
The bulbs are screw lug to fork connections. Not too much chance of error there either.
I still think it's a ground problem. I have all new connectors to replace all of them on the fender. I'll do that tonight. I also remembered one thing I did yesterday that might just be the culprit. The mechanic at the MF dealer said he has seen more fender mounted light trouble because of a bad fender to axle ground than any single problem. Yesterday, I messing with the stabilizer bars. I always ran just one. I bent one a few days ago, so I decided to get new ones. (TWO this time. I never noticed with just one, but the left side bracket was too far forward. (Mounting holes are slotted) I got under the tractor and smacked it backwards with a 2 lb hammer. That MIGHT have disturbed the fender to axle ground connection. It was about 5 minutes later when I noticed the lights weren't working.
So, I guess I CAN'T fix EVERYTHING with a bigger hammer.
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2024 Bobcat E35 Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Bobcat E35...
