3-Point Hitch No lift
   / No lift #1
2 Acre Farm
I have a 2301D,While tilling yesterday the 3-point suddenly quit lifting,The FEL still operates as normal. What should I look for as the problem?
Thanks.
   / No lift #2
Your stop valve didn't get accidentally closed did it? Does it try to lift at all?
   / No lift #3
Just had that happen to the ym2500 I had to go check out.Hyd. fluid was leaking at the pump. That was a easy catch because the motor would Bog Down from the pressure on the pump from the valve being shut.When I went to lift the bus hog.
Carey
   / No lift
It doesnt try to lift at all.The stop valve is not closed externaly.
I see no leaks,no strange noise.
   / No lift #5
I'm not sure on your model if its set up like my 2000 or the 2500 but under your seat is the control valve with a plunger in the back of it that is controled by your lift handle pushing the plunger in Lifts it, let it out lowers it.If that is working then losen the HYD.line to it and see if it's pumping fluid to it .Yes Bad Valve. If no then clogged filter or Bad pump. I'm sure you checked the fluid.I'm no expert but should get you close to the problem.
Carey
   / No lift #8
OK, loader is working so we know the pump is putting out. (Tractor pump does operate fel? not a crankshaft driven pump?) If you have fluid going to the control valve, stop valve is open, and all your external linkage is OK you are going to have to dig deeper. Do you have a manual?
   / No lift #9
I dont know about your tractor but my 3810D has a little blade lever under the seat on a block on top of the trans (to the right of the 3pt shut of knob) that controls the speed the 3pt moves from nothing to full speed you may have bumped yours if its equipt with one.
(it comes with auto draft only I believe but could very easily be wrong)
Also if you have the auto draft option you have another lever on the arms that kicks the 3pt control lever out in order to self control itself, you may have to do a search here for auto draft. If you moved that lever the 3pt wont go up with the main control lever either.
Steve
   / No lift
I took the cover off of the control valve. I cant see anything unusual,the shaft that appears to operate the valve has spring tension and moves in and out freely. I have a parts book that shows the valve,but it is in japanese.
The service manual I have is for a 330 and is quite different.Not sure if I want to take control valve apart or not.
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A53472)
Adams FL24...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
