No hydraulics to cylinders
   / No hydraulics to cylinders #1
WFOMO
Zetor 6245
Working with a friends T5C. Everything WAS working and suddenly no hydraulics to any cylinders. Hydrostatic drive works and power steering, just no outriggers/bucket/backhoe.
Oil level is full. Pulled hose off at the backhoe manifold and zero pressure. Removed plug at gear pump to where I could barely see the gear teeth, then bumped the motor. No movement on the gear teeth.
Unless someone sees something I'm doing completely stupid, I'm guessing I've somehow stripped the main shaft interface with the gear pump. If so, is this a gear pump replacement or a shaft replacement? If shaft, am I looking at pulling the entire hydraulic assembly out of the frame?
2019 WACKER NEUSON CORPORATION DBA WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2019 WACKER NEUSON...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A55852)
2014 Utility...
2011 Case IH Steiger 335 AFS Tractor (A53485)
2011 Case IH...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
2017 Ford F-150 Pickup Truck (A55852)
2017 Ford F-150...
Kubota L4701 (A53317)
