No Hydraulics on Massey 2310
   / No Hydraulics on Massey 2310 #1
dans12345
massey 2310
New member so bear with me:
Went to use my Massey 2310. It moves back and forth, but no hydraulics. It is an 05 and understand that that is a problem. It was repaired once under warranty and they said the splines on the shaft were too short and now it is broken again.
Any help or advice would be appreciated.
   / No Hydraulics on Massey 2310 #2
hey there... there is only one hyd pump in our 2310s. what splines are you talking about? splines on the pump? if it moves back and forth then the pump is working. does power steering work? how about front end loader? how about 3pt hitch? how about backhoe? I had a problem where my hoe stopped working but I think everything else worked. when trying to move the hoe I could hear teh main pressure relief valve squeel... turned out the 3pt hitch raise/lower lever had bent and was rubbing (hard) against the fender where the lever protrudes through the fender. Once I carefully bent the lever straight, I noticed that when I moved the lever all they way to the "up" position (all the way back if I remember correctly) the lever would stay there until the hitch raised to the full up position, then it pushed on a spring connected to the hand lever which moved the hand lever out of the full up position, allowing the hyd pump to stop pushing on the 3pt hitch mechanism. When bent, there was too much lever/fender friction for the spring to do its job and the the 3pt hitch hyd circuit was always pushing... and it was stealing hyd pressure from the hoe circuit.
now... other things to check - make sure all 3 quick disconnects are freed up that go to the hoe... there is one of them in particular that if not completely connected and blocked, will mess up a whole bunch of stuff... search for my other post where I describe my trouble shooting steps from a year ago...
Let us know how you make out.
This is the second time I have had this problem, where the tractor moves back and forth with no power steering, no back hoe or no front end loader. Brought the tractor back to the dealer, where they changed the hydraulic pump. I was told that the splines for the pump were too short. The exact same thing happened again, so that is why I am assumng it is another pump and I don't know how to check it for this problem. Thanks for your response. If you have any thoughts I would appreciate hearing from you again. dan
2016 Ford Focus Sedan (A50324)
2016 Ford Focus...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
Tesco 200 Gallon Tank (A50774)
Tesco 200 Gallon...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
